Home > Technical (L322) > Towbar bolt/coupling
lighthouse
United Kingdom 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
Hey All
I am missing the it that goes through the square fitting on the towbar that then goes through the bit pictures below to secure it. Does anyone know if i can just use m12 or whatever size bolt fits or is there a specific part? Looks like it takes the pull pull loading so needs to be strong.
Thanks
Post #546178 6th Mar 2020 11:49am
I'm sure there's a proper bolt & may be available as a separate item
Ideally you want a bolt with a pin through to prevent the nut ever shaking off, but TBH I would have thought any decent bolt would be fine.
I used to have a drop hitch with a pin if that provides any comfort
and another with a bolt and pin setup -
Post #546181 6th Mar 2020 11:57am
lighthouse
Thanks will go and get. decent bolt and drill a hole through the end to add a split pin.
I could not find a LR part number or know what its called to ring a dealer.
Post #546183 6th Mar 2020 11:59am
rjff
That looks like a Westphalia towbar and as such you should be able to get the correct bolt from a supplier.
As a start try PF Jones via their website/phone.
It may pay to use the correct bolt knowing how fickle insurance companies can be in the (unlikely) event of a claim. And it should keep you within the regs for CE use and construction of bars. Rolling Eyes Cheers
Richard
Gap IIDBT
Post #546198 6th Mar 2020 3:23pm
lighthouse
This was my concern hence looking for the correct part, just need to find out wha that is, will give pf jones a call.
Post #546200 6th Mar 2020 3:27pm
Even if they don't have the exact one, there is some advice on their site -
https://www.pfjones.co.uk/tow-bar-bolt-kits.html
Post #546216 6th Mar 2020 4:30pm
lighthouse
Thanks everyone for the help.
I spoke to a really helpful guy at PF jones who spoke to there team at Westfalia and they confirmed its a start M16 100mm long bolt with a hole for a split pin nothing special about it.
The also advised that if you can not source a split pin one then using a nylock nut is also ok.
Post #546220 6th Mar 2020 4:49pm
rjff
Great to know and that'll help lots of others Thumbs Up Cheers
Richard
Gap IIDBT
Post #546226 6th Mar 2020 7:19pm
