![]() | Home > Technical (L322) > 3.6 TDV8 - cracked driver's side manifold |
jonminns Member Since: 07 Mar 2011 Location: Leicestershire, UK Posts: 155 ![]() ![]() ![]() |
3,000 miles later i can report that the 291i is holding strong. I roughed up a large area with 80 grit paper, and cleaned meticulously with degreaser then IPA solvent. Applied the sealant in 2 goes, quite thick and worked it in as best i could. I applied a large area - around the size of my hand to cover a small crack so that probably helped.
