![]() | Home > Maintenance & Mods (L322) > Suspension - car keeps wanting to go into Extended Mode |
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352
First thing to do is drill out the sintered brass exhaust valve on the compressor.
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8002
And make sure the height sensors haven’t swung round and are upside down or similar.
| Ansi Member Since: 07 Nov 2014 Location: Muenchwilen TG Posts: 155
Yes, it looks like you have accidentally swung the sensors around be reinstalling. First thing I would do is to disconnect the sensor and swivel it around to the other side and see what happens. If worst comes to worst you have to order a new one which I did right away with the new struts when I had to change them. |
| Always Member Since: 04 Nov 2013 Location: Yorkshire Posts: 58
Hi.
Just feeding back with findings. Thank you Dr Rob. It was indeed the sintered brass exhaust valve on the compressor being blocked.
Bazinga! |
You prob saw my thread then where it was stuck in extended mode and I ended up drilling it out. Cos the air can’t escape fast enough to lower the car in a timely manner, it assumes there is an obstacle underneath so goes to full height.
I think a tiny hole is a good fix for it and a lot cheaper than what LR want.
| nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690
this is what I did with mine-
| All times are GMT |
