Home > Technical (L322) > Lower wishbone bushes
lighthouse
United Kingdom 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
Hey this car had an mot 10’days ago.
Anyone know how easy these are to do?
Post #546304 7th Mar 2020 3:53pm
Nick591
Those bushes are designed with gaps to help with NVH and the extreme suspension travel. Are you sure it has failed? Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8
Post #546314 7th Mar 2020 5:36pm
DrRob
Very easy. I get my mate to do them Whistle Rolling with laughter Rolling with laughter Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #546316 7th Mar 2020 5:37pm
DrRob
Buy from Paul at Advanced. Forum discount Bow down
https://www.advancedfactors.co.uk/front-su...-287-c.asp Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #546317 7th Mar 2020 5:39pm
lighthouse
You mean it should look like that?
Post #546318 7th Mar 2020 5:39pm
GGDR
Details here:
https://www.fullfatrr.com/forum/topic49324...=lower+arm
Did mine on the street, around an hour and a half each.
Only tool I needed to buy was this:
. Cheers, Greg
Post #546320 7th Mar 2020 5:41pm
lighthouse
thanks will buy a bearing tool normally use sockets and a vice but guess this way can do it without breaking the ball joint end.
Post #546322 7th Mar 2020 5:49pm
Nick591
Yes, it should look like that. If your steering is not feeling vague they are probably OK. The MOT tester will definitely have checked them as they are a known failure point on these vehicles and bushes generally are something they pay attention to. Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8
Post #546326 7th Mar 2020 6:39pm
lighthouse
Interesting thanks for the info, have a slight rumbling from the front sometime assumed this was the cause but maybe not, I ssumed all bushes were solid.
Post #546327 7th Mar 2020 6:42pm
They look Ok, the arms themselves look quite recent and are OEM Lemforder.
The easiest way to do these is to replace the whole arm. Bolt on/off then. The arms are reasonable, if you do decide to do them the extra 25 quid or so over the cost of a bush will seem worth it when you are trying to extract the bush and get it back in pointing in exactly the right way.
The rubber with the arrow isn’t meant to be attached, the other 2 at 12 o’clock and 4 o’clock are. There is nothing that can't be fixed with a hammer😜😜
Post #546330 7th Mar 2020 6:58pm
lighthouse
Feeling more reassured that these are normal now, thank you.
Post #546333 7th Mar 2020 7:19pm
dexion7
2010 Range Rover Vogue SE TDV8 Alaska White
here's a picture of the bush..
eBay item number: eBay Item No. 293207758176
Post #546417 8th Mar 2020 11:14am
