Home > Maintenance & Mods (L405) > Off side front seat creasing
jackcramerr
How can I avoid or slow down the creasing of the OSF seat? I don't know for some reason I have accelerated the process.
Thanks
Post #546627 9th Mar 2020 9:14pm
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
Side Steps
Post #546644 10th Mar 2020 12:29am
jackcramerr
Hi DrF.
I have deployable side steps. Thanks.
Post #546662 10th Mar 2020 10:00am
leather treatment of some kind? ... - .- -.
Post #546663 10th Mar 2020 10:05am
DrRob
Lower the height every time. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #546672 10th Mar 2020 11:55am
Andy S
United Kingdom 2015 Range Rover Vogue SE SDV8 Aintree Green
Jack,
Do you have the steering wheel and seat set to move away when you switch off? This should lower the seat cushion and if using the side step, you can lift your right leg as you get out so it doesn’t roll over the side of the seat. As for treatment of the creases, a good leather balm will make the leather more supple.
Post #546691 10th Mar 2020 3:36pm
jackcramerr
Andy
Thanks. How can I set the steering wheel and seat to move away?
Post #546703 10th Mar 2020 5:49pm
on the steering wheel adjust knob there is an auto selection...this will raise the steering wheel and move the seat down when the door is opened..when you close the door the seat and steering wheel go back to the set position.. ... - .- -.
Post #546704 10th Mar 2020 6:10pm
