![]() | Home > Technical (L322) > Temperature |
kds2 Member Since: 30 Sep 2017 Location: lincoln Posts: 226 ![]() ![]() ![]() |
Not had it long ? My td6 sits about straight up in the summer less in cold weather so maybe yours has been running cold till now. |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6428 ![]() ![]() |
The Temperature Gauge should be at 12 o'clock/midday once the car has reached normal operating temperature (can take up to 20 minutes with a TD6). Running at 10 o'clock or moving around means either your main thermostat or your EGR stat requires replacement.
Simon_CSK Member Since: 13 Feb 2020 Location: Ayrshire Posts: 132 ![]() ![]() ![]() |
Only a month and learning all the time Current cars Range Rover Sport HSE TDV8 Range Rover TDV8 Vogue Range Rover P38 Vogue Range Rover CSK Discovery 3 HSE |
Sits around the 10 position most of the time with some ventures into the 12. It doesn't constantly rise and fall. Current cars Range Rover Sport HSE TDV8 Range Rover TDV8 Vogue Range Rover P38 Vogue Range Rover CSK Discovery 3 HSE |
322BLL Member Since: 18 Apr 2019 Location: Estonia Posts: 73 ![]() ![]() |
Start with EGR one. Remember from past that e53 part was cheaper than l322. |
