![]() | Home > Technical (L322) > New key? |
| nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2075
Oh yes from a stealer, and sit down as they are around £200 |
| pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865
maybe buy something like this
| letsavit2 Member Since: 16 Oct 2010 Location: essex Posts: 854
your only program it to open the car, not start it. 2004 black Vogue TD6 |
| dan_uk_1984 Member Since: 12 Nov 2008 Location: Bude, Cornwall Posts: 4014
Frustrating because the original part used to be around £10! When it was on Part# CWE000090 then it was superseded to YDM000010 as is a ridiculous £175!
| Gazellio @ Prestige Cars Member Since: 22 Jan 2010 Location: Chilterns, UK Posts: 11309
Plus you will need to pay someone with full Land Rover Tech to program it to "Start" the car as the lock programming will not work for the immobiliser....
| 47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048
Key for the early models come programmed to start the vehicle, but they need to be coded to open the doors, The early cars don't need the keys to be set up on the computer but the later models do. |
Anything Facelift will defo need LR programming. I had a new key on a 55 SC and that needed programming to start the car. Its easy to program the new key to locks yourself |
does this mean if he buys the key in my link and gets a new blade for it that it will start his car ? "RANGEISM WILL NOT BE TOLERATED" www.futuresecurityservices.co.uk Pretlove says , '' I want my car back |
| Reformed Member Since: 09 Oct 2010 Location: South Posts: 471
I only have one key with mine (2003 Model), and my local dealer (Guy Salmon) has quoted me £221 inclusive, for the key, car and immobiliser programming.
No, he will need a new key from LR or he could change the case over from your key and throw the interior parts away |
| M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325
I need a new key for mine, I only have 1 for the car and I'm paranoid that I'll lose it, same goes for my work van only got 1 key for that too.
LR requires you show them proof that you own the vehicle by producing the log book and you also need your driving license or passport as proof of who you are. The new key does come pre-programmed to start the vehicle, but has to be programmed to open it, a simple enough task which can be read here |
| Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470
The key is made of 3 parts. 1) blade needed to turn the barrel and start, easy to change get new ones, 2) electronic button bit, can be programed to open/close doors etc. Any key which is the same on eBay can be programed by yourself to open/close. There are BMW keys that can be used, 3) transponder chip! This is the hard bit which needs dealer programing to talk to the immobiliser. If you have spare keys with worn buttons the chips can be moved from key to key but if you only have one key it's a trip to the dealer to be dry humped in exchange for a new key. |
And can take for ever to arrive, as they have to be ordered from Germany |
