![]() | Home > Technical (L405) > L405 Deployable Towbar |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16365 ![]() ![]() ![]() |
I would imagine the mechanics would be the same BUT... The 405 has different control units dependant on age. So, i would think most of the towbar would work and you may need to buy a different loom, switchpacks? & control unit (ECU)
Craig Member Since: 24 Mar 2020 Location: Lichfield Posts: 3 ![]() ![]() ![]() |
Thank you for your reply.
Flyingfocrs Member Since: 18 Oct 2016 Location: On the croft with the horses Posts: 93 ![]() ![]() ![]() |
I can tell you that the strengthening bracket for the Sport is completely different to the full fat one.
Thanks. I have downloaded the fitting instructions of the L494 off the Land Rover website and can see what you mean. The L494 re-enforcing frame "splays" at the end and bolts on differently to the main towbar.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8751 ![]() ![]() ![]() |
Had a think about fitting a deplorable one to mine. Decided on a simple detachable like I had on the 332. I know it works well, and I don’t have the problem of it not deploying and locking. (And a few quids in the pocket in savings) There is nothing that can't be fixed with a hammer😜😜
