![]() | Home > Technical (L322) > TD6 now has a deep burble |
Anvil Member Since: 18 Jan 2019 Location: Dorset Posts: 140 ![]() ![]() |
Catalyst element dislodged? You can test if there is a leak in your exhaust by putting a hand wrapped in a rag over the pipes to temporarily block it. It should build up a lot of pressure quickly without any hissing sounds from under the car...... |
