Home > Technical (L322) > What new battery do I need
Greyskull
England 2009 Range Rover Vogue SE TDV8 Buckingham Blue
Hi all I’m having problems with a flat battery what is the recommended one to fit on a 2010 3.6 v8 .ive looked in the forum and still not sure, wat is an AGM battery ??
Post #548689 29th Mar 2020 3:43pm
Fox889
Try www.tayna.co.uk & put your reg in the search box.
Should come up with a choice of batteries, these guys get good reviews. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #548703 29th Mar 2020 5:21pm
Greyskull
Will do thanks πŸ‘πŸ‘
Post #548721 29th Mar 2020 6:41pm
alfapat
Scotland 2004 Range Rover Vogue Td6 Bonatti Grey
Re: What new battery do I need
Agm is a gel filled battery rather than standard lead acid , usuall more expensive and requires a more suitable charger, can fail still the same in my experience.
Try and check to see if your alternator is charging and that nothing is draining it.
Post #548736 29th Mar 2020 7:49pm
If your car isn’t set up for an AGM then don’t fit one.
AGM batteries require different charging voltages than an lead acid battery. Some of the 3.6 cars did have AgM Batts but check first.
As said Check the charging voltages. Look in the hidden menu and you can see the alternator voltages.
Search the forum for the hidden menu. There is nothing that can't be fixed with a hammer😜😜
Post #548768 29th Mar 2020 10:33pm
Greyskull
Thanks for your reply’s πŸ‘πŸ‘πŸ‘πŸ‘πŸ‘
Post #548771 29th Mar 2020 10:59pm
Greyskull
Thanks again , ordered one from tayna batteries put Reg no in got one at a decent price compered to some so will see how it goes.. thanks to FOX889 πŸ‘πŸ‘..
Post #548795 30th Mar 2020 10:42am
