![]() | Home > Wheels & Tyres > how to run 35 inch tyres on the L322 |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 ![]() ![]() ![]() |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
Hi
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2621 ![]() ![]() |
Plenty of pictures of them with 33” - might suggest 35” is a lot more work. |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8090 ![]() ![]() ![]() |
I'd agree - it will be a disproportionately large effort for an extra inch of clearance under the diffs - but you don't seem to be put off by a challenge.....
Charles89 Member Since: 11 Nov 2018 Location: Leicester Posts: 268 ![]() ![]() ![]() |
Are you sure?.... I've researched everywhere, and all I seem to find is that the L405 4.4SDV8 has such large calipers on the front that 20" wheels are the smallest wheels you can get onto it? Have you tried 19" wheels on yours? I do like the idea of some extra rubber, so if it's a sure thing I will get some 19s ... |
No to phased no... but I am also exploring other options for more lift and clearance. Of course true lift comes from bigger tyres because it's not raising the body. So this is why I was looking to fit 35" tyres |
Agree - true lift = bigger tyres, but the body will have to rise also - assuming you want to get as much articulation as possible
Thanks for the info.. looks like I will need to buy an after market 6 piston caliper set up in a smaller diamiter. I found AP racing brakes that will fit. Thicker vented floating discs, but smaller diameter of 355mm allowing for an 18 inch wheel fitment, rears can then use same calipers but reduce to the 3.0tdi discs and carriers. Then you can fit modular steel wheels 18 inch 9.5J wide with 305 75 18, should make for great off road performance.
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3269 ![]() ![]() ![]() |
For information, I have a set of the 501s in Alistair's link with 23/65/29 tyres on them. They were sold as being 405 take offs. They fitted my 2008 Tdv8 with the 4 pot Brembos.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2742 ![]() ![]() |
Better to fit 275/55R20 than any 19" as there isn't much available in 19" yet lots in 275/55R20 including at least 1 LT. 275/55R20 are barely 32" and fit the L405 without any rubbing. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8765 ![]() ![]() ![]() |
Definitely fit 19” on the 4.4 with the 6 pot brembo.
PM me a price and maybe if your up for it I can pop over and try one on and take them off your hands |
They aren’t going anywhere until this lockdown is done 👍🏻
great thanks |
