Home > Maintenance & Mods (L405) > roof rails kit, why panoramic is different
karba78
France 2013 Range Rover Autobiography 5.0 V8 Baltic Blue
hello
looks like the roof rails kit from LR are different if you have a panoramic roof or not
well more specifically the finisher are different not the rails
does anyone know why and what the difference is
this 2013 L405 V8 5.0 Aspirated Autobiography
gone 2005 LR3 V8 4.4 HSE
1999 TD5 Defender
Post #549194 2nd Apr 2020 9:55pm
Vogue
Because the glass panel / roof is different to accommodate the opening mechanism. I fitted a set to mine - probably took 1hr all in if you are switched on with working on cars. They are not supplied with fitting instructions - these are available on line - the rails come with a QR code that you scan to get the instructions onto your phone or pad. A search on the LR website should also throw the instructions up. 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #549208 3rd Apr 2020 7:26am
karba78
thats helpfull thks
will search for the instructions; if you have a url pls do not hesitate sharing
so far only found the normal roof one http://accessories-instructions.landrover....2020430101
could not find the panoramic one their site, d
thks again 2013 L405 V8 5.0 Aspirated Autobiography
1999 TD5 Defender
Post #549217 3rd Apr 2020 9:44am
Charles89
United Kingdom 2014 Range Rover SVAutobiography SDV8 Scotia Grey
I bought mine from Powerful UK and they didn't state anything about panoramic or non panoramic, I didn't even know there is a difference, I installed them regardless and then seem fine Smile
Post #549823 10th Apr 2020 6:58am
karba78
checked with J Crdck and it seems only the finishers are different
here is the recommended parts
VPLGR0098
and
VPLGR0078 2013 L405 V8 5.0 Aspirated Autobiography
1999 TD5 Defender
Post #549855 10th Apr 2020 10:44am
Vogue
Correct - it is just the finishers / trim which are different - the rails are the same 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #549864 10th Apr 2020 1:29pm
