![]() | Home > Technical (L322) > Whop whop noise? |
bruce Member Since: 21 Jun 2009 Location: Cumbria Lake district Posts: 90 ![]() ![]() ![]() |
Distant helicopter perhaps. If you are not part of the solution you are part of the problem!! |
jim4244 Member Since: 31 May 2012 Location: UK Posts: 855 ![]() ![]() ![]() |
Bruce, read your own signature 👍
A calliper stuck/sticking! Drive it a while then put your hand on each wheel and see if one is much hotter than the others? 👍 |
Thanks Cam 👍 |
Took the old girl out for a 5 mile drive (the rangie not my wife) and then measured the temperature of the brake callipers.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8775 ![]() ![]() ![]() |
Make sure to take the Caliper carrier off the car and thoroughly clean with a wire brush/grinder brush wheel if possible. They rust which makes the pass stick in them. Sometimes it’s the pads sticking in the carrier rather than the Caliper itself. Worth trying as it’s a free fix if it works.
I removed the carrier and calliper and cleaned as you suggested.
When you refit the pads make sure the just pop in nicely. You shouldn’t have to force them in at all. There is nothing that can't be fixed with a hammer😜😜
All back together now. What a #£&*@+ of a job it is to replace the handbrake shoes!
Glad its sorted Jim... |
coolio.
stu1 Member Since: 06 Dec 2013 Location: UK Posts: 276 ![]() ![]() ![]() |
Nicely done |
Stu, how many times did you swear when trying to engage the top spring back in both shoes? 😂
