![]() | Home > Maintenance & Mods (L405) > Front Pads 4.4SDV8 |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3556 ![]() ![]() ![]() |
Go EBC Mark |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8776 ![]() ![]() ![]() |
will have a look. tbh the brakes in the 405 seem to have way more bite than the 322, which is weird as they are the same setup. Looking at the discs and pads I reckon its on its second set of pads and original discs. Deffo going LR on the discs, they are probably Delphi, but no way of knowing for sure.
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1865 ![]() ![]() |
They can be had MUCH cheaper than £160 |
I paid £138 in 2019
Just checked the price from my supplier.
Ooo. Are the yellow stuff that much better, are supposed to be road and track.
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
Yellow stuff used to be track use but the latest compound is equal to the green stuff in initial bite when cold and much better with some heat in them. I had yellow stuff on the front on my 2011 4.4 TDV8 and greenstuff on the back ( couldnt get yellowstuff at the time )with EBC discs all round and found them excellent with zero fade and alot less dust. I havent had to change the pads or discs on my L405 but will probably go the same route when the time comes.to change. Just my pennies worth, I'm sure there are plenty of other opinions |
Yellowstuff are marketed as high friction and high heat capacity, but
https://www.johncraddockltd.co.uk/da4739-e...10-on.html
150 plus for the yellow stuff.
