|  | Home > Maintenance & Mods (L322) > Should I replace spark plugs? |
| Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 701      | OK, first port of call is the service history [assuming it has any?] If it's had plugs in the past 50k then they're probably ok. If there's no history of plug change and/or oils & filters then I personally would start from scratch & do everything in a reasonable time frame. 100k on original plugs is pushing the realms of reliability a bit too far, they would have been changed at some point......surely?
|  9th Apr 2020 7:34am |
| Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1885    | With ANY car I purchase, it gets a full service. All filters, and plugs if a petrol car. At least then, you know where you stand with things
|  9th Apr 2020 8:12am |
| JohnGalt11 Member Since: 31 Mar 2020 Location: Iowa Posts: 27      | That's pretty much where I'm at as well. I have the carfax, but it isn't a complete history. Engine oil looks fine for now, as does brake and power steering fluid. I blew out the air filters just for grins but they were clean, too. I did coolant flush, transfer case, and transmission fluid over the last two weeks. Waiting on a fill plug and fluid for the differential(s) change, but should knock that out this weekend. That leaves..... Plugs and fuel filter? Suppose I should figure out where the fuel filter is and how to change it.
|  9th Apr 2020 12:31pm |
| Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 701      | Being slightly OCD in the oil department, if that were mine, I would drop the oil & filter for two reasons 1) no idea who’s oil is in there & how long and 2) piece of mind that ‘my preference’ of oil is in there. Oil is not expensive compared to what you paid for the car so do the RR a favour & drop the oil. Oh......while you’ve got your head under the bonnet change the plugs!😂😂 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
|  9th Apr 2020 3:35pm |
| Classic888 Member Since: 10 Jun 2015 Location: East Yorkshire & Hertfordshire Posts: 233    | If I recall correctly, Land Rover recommend that the spark plugs are changed at 105,000 miles under "normal " driving conditions. The fuel filter is part of the fuel pump in the tank. | ||
|  9th Apr 2020 3:43pm |
| JohnGalt11 Member Since: 31 Mar 2020 Location: Iowa Posts: 27      | Fox889, I agree with you on the engine oil change. Just put it off in terms of priorities. I can look at the engine oil and make some determinations as to the wear it has endured. I can't easily do that for any of the other oils, so they went first. There are brake fluid, and coolant flushes periodically on the Carfax, which is good. I didn't see any reason to think that ATF or differentials had ever been touched, but luckily there was no metal on the magnets on the ATF pan, and the transfer case oil didn't look terrible. But as others have said, better to change them so you can be sure. Shopping for plugs and a fuel filter now....It's only money, right?   | ||
|  9th Apr 2020 5:17pm |
| Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 701      | It is 'only money'.............it's just that you'll need plenty of it with a FFRR 😝  | ||
|  9th Apr 2020 6:27pm |
| JohnGalt11 Member Since: 31 Mar 2020 Location: Iowa Posts: 27      | Thanks for the advice, Gents! I changed out the plugs this afternoon and then took it for a 50 mile drive on the highway to make sure everything was working properly. Got 18 mpg at 80 mph on a 50 mile loop. The only reference I have is that the day I brought it home I got 15.1 mpg at the same speed on similar terrain and similar wind conditions. Is that possible that I got a 20% improvement in fuel economy from just the plugs? I can't imagine changing all the drive train fluids made much difference in mpg. 2009 L322 SC | ||
|  13th Apr 2020 3:00am |
| Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 701      | You blew out the air filters + new plugs......all adds up to a more efficient engine I would say.
|  13th Apr 2020 11:09am |
| JohnGalt11 Member Since: 31 Mar 2020 Location: Iowa Posts: 27      | In case anyone was wondering what a 101K mile spark plug looks like. I'll never wait that long on any vehicle again. It cost $60 and took about 1.5 hours start to finish.
|  13th Apr 2020 5:58pm |
| Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 701      | Holy Toledo! That's a worn plug for sure.
|  13th Apr 2020 6:36pm |
| All times are GMT | < Previous Topic | Next Topic > |
| Posting Rules
