![]() | Home > In Car Electronics (L322) > Ulf Range Rover Bluetooth upgrade |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000 ![]() ![]() ![]() |
You have to short them together with them still connected, if that makes sense.... ie you are earthing one of the wires through the other, as one is ground. Sorry, can’t remember which one. It’s years since I did it. Think there is a procedure somewhere....
Lee1974 Member Since: 09 Apr 2020 Location: West midlands Posts: 17 ![]() ![]() ![]() |
So put pin 32 in as 36 is already installed and then with the wire off pin 32 sort touch pin 36 that right |
More info on here, first 2 pages.
You don’t need to get into the pins.... anywhere on the brown wire can be used to short to....I cut it and joined up again with a choccy block. Then I pushed the white wire into the metal bit on the choccy block to short to it, hence leaving the brown wire still fully connected and grounded. 2011 Range Rover Vogue SE 4.4 TDV8
Still lost lol
Wire on pin 36 should be brown. Fully connected up.
Ok I get it now lol so if I cut brown wire pin 36 and join up with a block conector
Yes, that’s how to do it, but you need to then follow the pairing procedure that’s in the other thread I linked to.
-With the ignition off, press and hold the pairing button on the cradle (not the wheel).
Not got pairing button ? |
The pairing button is you shorting the wires together..... so you will have to short them in the boot...dash to the front to turn key and then dash back to separate the wires etc.
Ok I got it so connect them got turn key dash bk to rear I short them then should see show up on phone |
Are u from Kirkby in Ashfield thought seen you motor around by there ? |
I’m in Chesterfield.
