Home > Technical (L322) > 2006 RR Sport SC, “transmission fault, traction limited”
Indirocz28
United States
Hello all, new rover owner here.
I just picked up this decently clean 2006, and I wanted to check the differential fluids before a trip this weekend. First let me start off by saying I am mechanically inclined, but that doesn’t mean I’m perfect, or familiar with something new.
On the rear diff, to the driver side of the pinion there is a long “nut” that is spring loaded.
I mistook this for the differential fill plug.
And after filming I got a “transmission fault, traction reduced” error.
Could it be the fact that I most likely over filled it, or is it because I removed that spring loaded pin/nut assembly?
Thank you.
Post #549989 11th Apr 2020 1:33pm
welcome but you have come to the wrong forum...
try our sister forum dedicated to range rover sports where you'll get a more accurate answer.. ... - .- -.
Post #549993 11th Apr 2020 1:48pm
Indirocz28
United States
What is that forum?
Post #549997 11th Apr 2020 2:22pm
http://www.rrsport.co.uk/ ... - .- -.
Post #549999 11th Apr 2020 2:28pm
Indirocz28
United States
Thank you for clarifying.
Post #550003 11th Apr 2020 3:39pm
