Home > Technical (L322) > Funny air noise
Duke Thrust
Funny air noise
Chaps,
Getting a funny air noise from behind the dash, sounds like someone blowing over a top of a milk bottle.
Had the 'stat changed recently as the battery was draining over night, thinking they might be related? Something could have been disturbed?
Anyone had anything similar?
4.4 BMW V8, Vogue
Post #59203 7th Apr 2011 9:27am
M44K TS
Funny enough, yes, on Saturday on the motorway I got the same noise only for about 5 sec, haven't heard it before and hasn't done it since, I thought it might have been the top section of the drivers door seal as it needs a new clip from when it froze to the bodywork and got pulled off when it was below freezing around Christmas time 2006 Mercedes CLS
1991 Retro-style Mini
But really finding it hard to fight the urge for a S/C...
Post #59249 7th Apr 2011 12:59pm
Sounds like the Fuel Burning Heater to me. Discovery 4 HSE
1998 90 TUL FFR Hard Top XD Wolf
1993 90 Tdi
*Gone: L405 4.4 VSE, L462 D5 HSE LUX, L663 Defender 110 HSE, Discovery 3 HSE, 2014MY Range Rover Sport 5.0 Supercharged AB Dynamic; L405 Exec Vogue SE 4.4, 5.0 Supercharged Autobiography, Defender TDCi XS CSW, Defender TD5 HT, Vogue SE TDV8, Vogue TD6, RRSport SC 4.2V8, Classic 3.9 Vogue Auto, Land Rover Series 3 SWB
Post #59254 7th Apr 2011 1:18pm
mzplcg
LOL, I had the same issue a while back. Mine turned out to be a combination of a rag and a 1L can of oil wedged in with the battery. If there's anything in that space other than the battery it whistles big time.
Dom
Post #59255 7th Apr 2011 1:20pm
Baben
South Africa 2014 Range Rover Autobiography SDV8 Luxor
I have had the same experience! Sounds exactly as you describe - blowing over the top of a bottle - seems to come from under the steering wheel. Seems to happen only when cruising on the highway, perhaps twice to three times an hour. I don't have the FBH, so it can't be that. mentioned it to the dealer, but they can't even sort out a squeaky front suspension....
Post #59260 7th Apr 2011 1:52pm
dan_uk_1984
The scuttle panel can lift around 50-60 seems to be its "sweet spot"
Post #59264 7th Apr 2011 2:13pm
Vogue
windscreen washer pipes vibrating on the scuttle near battery also causes a similar noise at 70ish
Post #59265 7th Apr 2011 2:18pm
Duke Thrust
Hmmm! The battery was replaced too, I wonder if the washer pipes were disturbed...
Post #59268 7th Apr 2011 3:20pm
Vogue
thats exactly what mine did after the battery was replaced!
it could al;so be the scuttle vibrating as Dan says. The trouble is some garages don't put the bonnet into access mode to replace the battery, they force it in and lift the plastic scuttle. The scuttle is stuck to the windscreen with adhesive tape, if it comes loose then it vibrates against the glass.
I would check your pipes first - I used cable ties and insulation tape to secure them. If this doesn't work, check the scuttle is still stuck to the glass.
Post #59270 7th Apr 2011 3:38pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Sorry, not adding anything useful just find it really funny how we're driving our very own orchestras depending on how fast you go/how sh4gged out the car is!
Post #59271 7th Apr 2011 3:39pm
Vogue
it was the peasants at my battery depot that goosed mine Sad
Post #59277 7th Apr 2011 3:56pm
Duke Thrust
How did you fix? Off with the scuttle, new tape and back on?
Post #59280 7th Apr 2011 4:12pm
M44K TS
It was just before Christmas I replaced my battery, I've probably arsed something up, I'll check it later. 2006 Mercedes CLS
Post #59282 7th Apr 2011 4:20pm
Vogue
heat gun, very very gently did the trick - seemed to reactivate the sticky - and pushed back down hard
Post #59286 7th Apr 2011 4:41pm
oodathort
I dont think scuttle is glued down
Post #59320 7th Apr 2011 9:01pm
