![]() | Home > Maintenance & Mods (L405) > Question for the avid car detailers |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3556 ![]() ![]() ![]() |
Not driving it?
AnotherMutley Member Since: 16 Jan 2017 Location: Kent Posts: 400 ![]() ![]() |
Its currently enjoying a holiday in Essex having its coolant leak attended to by one of the few dealers still open for emergency work, when it was loaded onto the big yellow truck I noticed how bad they looked. |
Buz1500 Member Since: 05 Sep 2011 Location: Cumbria Posts: 369 ![]() ![]() ![]() |
Have a look at this....
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1041 ![]() ![]() |
What a faf that guy is........just use a wet and dry vac like you would on any carpet. |
LT Member Since: 13 Mar 2017 Location: South West Posts: 417 ![]() ![]() ![]() |
What are the advantages of using this fabric material for the arch lining? |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 ![]() ![]() |
Sound deadening, stops the sound from the main culprit in modern cars.... tyre noise. |
jim4244 Member Since: 31 May 2012 Location: UK Posts: 855 ![]() ![]() ![]() |
It also reduces water spray when the roads are wet and helps with visibility for vehicles passing or being passed.
Its world problems then |
Bradders Member Since: 03 Dec 2018 Location: Gods own country Posts: 417 ![]() ![]() ![]() |
Looks cr*p, retains moisture but is probably cheap to manufacture....... Current: FF Westminster money pit
Chalky Member Since: 10 Feb 2018 Location: Marshfield, Bath Posts: 931 ![]() ![]() |
Nasty crack in the windscreen at 6:05 |
I thought that was a reflection but you're right it looks like a serious crack. I'd be seeing to that before I spend all day cleaning my wheel arch linings but I guess you can't get Autoglass out at the moment. Current: FF Westminster money pit
Huwrhys Member Since: 07 Feb 2018 Location: Hornchurch Posts: 548 ![]() ![]() ![]() |
Tried watching but fell asleep after about the second wheel nut. Made it through by turning off the sound off. |
I've always thought this guy would be good to narrate Thomas the Tank Engine if they ever brought it back. |
