Home > Range Rover Classic > Re-assemble of dashboard / what repair manual?
flashgordon
Germany
The car I bought (from 1991) is excellent with no rust/corrosion at all.
Unfortunately the pre-owner removed parts of the dashboard (all parts seem to be there) and I need now to re-assamble.
In this moment I have no repair-manual (by the way: is there a standard manual that you would recommend for do-it-yourself ?) and am not quite sure in which order I need to re-assemble
steering column cover is off and wooden main panel, vents are removed ....what is „clipped on“ what needs to be screwed on, where to be careful, what is tricky or not...
For my former Jeep Wagoneer I used the „Haynes Repair Manual“...very helpful also for non master mechanics...
Post #550759 18th Apr 2020 10:02am
flashgordon
Germany
I plugged in the 4 plugs for air/heater
each plug has a black and red cable...
Does it matter which way I plugged them in ... I did black on top and red below black...
UPDATE: Yes, works. At least I can hear the fan running...
And I found these 2 cable plugs (blue and black) beyond the steering column . Anybody know what they are used for?
I see no counterpart to plug them in ...
And then I have 2 plugs (bigger white one and a smaller black one) in the panel above the 6 buttons (see picture). What are they for (I found not counterpart to plug in either).....
and one more question... the previous owner removed the radio.
In the open and empty slot is no „rack“ where I could slide/push a new radio in.
I expected a kind of standardized kind of metal rack / rails... something that keeps the radio in place..
And am I right that the is a small panel missing that would cover/ frame the radio (I think the place where the white tape with „2223“ on it should be covered somehow ...
Post #550770 18th Apr 2020 11:51am
Stephen.Gazard
United Kingdom 2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
Red and black wires for fan are the lights therefore doesn’t matter which way.
The white triangle one etc is for mirror control switch etc .... Stephen Gazard
Range Rover L405 LWB SVA Overfinch / Bespoke
Maserati GT 2017
Maserati Levante Trofeo
Mercedes SL63 AMG
Mercedes S500L
Post #550872 18th Apr 2020 8:59pm
flashgordon
Germany
Thanks . It works again.
Post #551718 26th Apr 2020 1:54pm
