![]() | Home > Technical (L322) > Flickering leds |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8774 ![]() ![]() ![]() |
Probably something to do with the Balast resistors on the rear lights. There is nothing that can't be fixed with a hammer😜😜
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35831 ![]() ![]() |
have a look at he conversion threads in the wiki or do a forum search, i'm sure theres something on this.. ... - .- -.
Paddocks67 Member Since: 17 Apr 2020 Location: Glasgow Posts: 28 ![]() ![]() |
Hi I've changed the resistors on the back lights I bought fix from powerfuluk and I still had the same problem,so sent them back,bought gap iid and turned all lights hot and cold off from lcm,and still happens,can't figure this out at all,as it just happens randomly.is there anything else to check,had the LCMs out that looks fine,just leaned the contacts with contact cleaner,cheers pat |
It would help giving some more details on age & model of your car. How you did the conversion or did someone else do it? |
Hi Craig,Isis a 2008 tdv8,I never done the conversion,so don't know how it's neen done it has two resistor boxes on the back lights the front halo,s they have seemed to have connected them via front side lights which are now not operationa,I read somewhere that someone said he turned all the lights off on LCMs and didn't need to use box resistors on back lights,will that work,cheers pat |
