![]() | Home > In Car Electronics (L322) > Vehicle Jerks to Subwoofer Beat While Accelerating |
| Roi354 Member Since: 06 Feb 2020 Location: Essex Posts: 32
You need a split charger and a leisure battery to smooth the peaks and troughs that the alternator is seeing on its load. I did suggest this in your last thread.
| Jasdip Member Since: 12 Mar 2012 Location: Canada Posts: 25
I read up about split chargers and understand how they work now. I read that they cause about a 1V voltage drop when wired into a system and that a alternator regulator is recommended. I also read that they are built into alternators. Is this something that I would need?
Connecting two batteries together will create a different scenario to introducing a split charger between them.
Just an update:
| Biggles1957 Member Since: 05 Dec 2017 Location: Leicestershire Posts: 28
You absolutely sure you're not tapping your right foot in time to the beat.... |
I’ve thought of a lot of crazy things, like my head and body are just vibrating and therefore I think the RPM needle is lol.. or the vibration in my body is making me feel like the truck is jerking.. but I’ve ruled those out! Lol |
