Good morning all,
So I explain my problem to you. Range rover l322 V8 SC vehicle.
My problem started with a lambda probe which apparently had a mass problem. After a lot of research with changing the probe, checking the beam, the solution to the problem was found: it is at the ECM that this happens. Between pin 34 (the mass of the lambda probe in question) of the ECM and the mass of the vehicle that things are not right. The circuit is open, whereas there should be continuity. The problem does not come from the soldering of the pin on the ECM electronic card I checked. So here is for me the simplest replacement of the ECM because as it does not receive the good info from the lambda it enriches to the maximum, the consumption is huge, seeing the engine and above all I can not repair the electronics like that.
So buying a new second-hand ECM, reprogramming with SDD that I have, it injects the VIN of my car well into nickel. Only I have the immobilizer blocking the thing. Error code U042600, meaning immobilizer code error. On the manual it is marked with a reprogrammer as the new ECM and the instrument cluster. Done, the operation for the instrumentation cluster is determined, for the ECM at a moment I ask for a blank module and the installation stops. In short, the error code still present.
So can someone tell me to re-program the immobilizer with SDD so that the immobilizer code is injected into the ECM?
