Home > Technical (L322) > Vacuum leak 2004 m62
bboldt3
United States 2006 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
First post go figure it’s about a vacuum leak!
Smoke tested and found a small leak at throttle body clamp, but also smoke comes out of the cyclone at two points.
I’ve attached a video it looks like their ports for pulling air in or should these be capped?
Can someone confirm, please
Ben
Post #553280 9th May 2020 7:05pm
Well I can see smoke but can't see where it's coming from..!! Pretty sure there is a diagram in the workshop manual which you can download from the wiki above.. Pete
2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior-Click here for Thread-
Post #553281 9th May 2020 7:10pm
bboldt3
Problem solved!!
I looked at the old cyclone and it has caps over these ports that’s where it was leaking!
Post #553284 9th May 2020 7:34pm
Glad you found it.. Pete
Post #553292 9th May 2020 8:44pm
bboldt3
Rookie mistake not comparing the new part to old
ThankS
Ben
Post #553293 9th May 2020 8:46pm
