Home > Maintenance & Mods (L322) > Auto Electrician needed
Sandyt
Anyone know of a good electrician I need to have a fault in the loom found Ta
Post #552722 5th May 2020 8:47am
Dizzy Dee
Yes, but in Croydon, so not too far from you.
A&A auto electrical. https://www.a-aautoelectrical.com/
If you decide to try them, tell them Dave from Orchard in Carshalton sent you.
I'm not sure what they are doing at the moment, but worth a call.
What is your problem, someone may have had the same problem and can tell you places to look.
Post #552835 5th May 2020 7:18pm
Sandyt
Its an interesting one the heated seats have stopped working so swapped out the switch pack still the same did put it in to na indie who found a broken wire and it worked for a few days but stopped again - I also have an airbag light which appears and disappears on the 11d tool diagnostics nothing but did have an odd suspension fault so my guess is a wire has a bad connection somewhere near the ignition switch so need a sparky to go through it all and find it
Post #552840 5th May 2020 7:46pm
Garnerj
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
Doesnt help in any way but having spent a bit of time digging through the loom on the wifes fatty this week and I can see why we have a few gremlins every now and again, wires joined together by twisting them and then insulating tape over and taped back into the loom. And no, its not a bodge job by someone after as its exactly the same in 2 cars in the same place. Look slike its the factory way of doing it! Sad
Post #553365 10th May 2020 6:34pm
Sandyt
Yes must admit have been disappointed with what I have found so far - there are a lot of taped slices nuts Shocked
Post #553367 10th May 2020 6:43pm
