Home > Maintenance & Mods (L405) > tow bars
andyleeds
United Kingdom 2005 Range Rover Vogue Td6 Zambezi Silver
tow bars
does anyone know what / if the 405 has as standard regarding tow bars? ie if it doesn't have the hook does it have the other bits.....? an l322 that i had didn't and it involved quite a bit off work to fit one which i dont want to do in future. but if relatively straight forward then i would consider etc
cheers
Post #552740 5th May 2020 10:12am
Ideally, but one with a towbar already fitted
The deployable one in particular is a very expensive retrofit.
https://www.fullfatrr.com/forum/topic39743.html
Post #552741 5th May 2020 10:17am
CS
AFAIK there is wiring but no armature or hook etc. I had the farmer's hitch type retrofitted, which is cheaper, simpler and stronger than the deployable one, and it's quick and easy to take the hook bit on and off. I prefer it to the deployable as no mechanism to seize up, but I think there will be fewer cars that have them, so harder to find one. Only Range Rovers since 1988
Post #552779 5th May 2020 2:15pm
can i ask how much did yours cost to fit chris.. ... - .- -.
Post #552787 5th May 2020 2:59pm
A little more info on this thread - https://www.fullfatrr.com/forum/topic50908.html
There are others who've retro fitted a detachable bar - I think NMJ & Redmerle have both done it.
600-1000 is the ball park range IIRC
Post #552790 5th May 2020 3:11pm
CS
It was £990 incl VAT in spring 2018, at main dealer as part of the overall purchase deal, looking at the accessory price list of the time there is not much difference to list price then. Only Range Rovers since 1988
Post #552792 5th May 2020 3:21pm
thanks Chris..
@Alistair, Thumbs Up ... - .- -.
Post #552793 5th May 2020 3:31pm
@Andy, found this site selling for £321 [£5 shipping]
https://www.towbars-uk.co.uk/shop/towbars/...le-towbar/
looks like a proper jobby and you can also download the fitting instructions so you can see how hard it is to fit the towbar.. ... - .- -.
Post #552801 5th May 2020 4:00pm
There is also a Westfalia detachable option, though not official LR, it’s a very similar system to the one on the 322. Think mine was about £600 fitted with 13pin electrics. There is nothing that can't be fixed with a hammer😜😜
Post #552852 5th May 2020 9:27pm
