Home > Maintenance & Mods (L405) > 4 wheel removal? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34913 |
this is from the WM [download link in the wiki]
8th May 2020 5:33pm |
Lordackers Member Since: 28 Feb 2020 Location: West Yorkshire Posts: 32 |
Thanks Stan, I’m still not sure if it’s safe to jack and remove all the wheels at the same time? |
8th May 2020 5:46pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7908 |
The dealers put them on a ramp and take all the wheels off when doing a major service, nothing to worry about.. Pete
8th May 2020 6:47pm |
gilesharrison Member Since: 04 Aug 2018 Location: Cumbria Posts: 163 |
Course it is! |
8th May 2020 10:09pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3673 |
Loosen the wheel nuts a fraction before you lift it and you will be fine....exactly the same as using a 2post ramp.
9th May 2020 8:13am |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
If putting it on four stands, even at a conservative 2ton per stand that would be a 2 ton vehicle on 8 tons of stands. So plenty of SWL.
9th May 2020 11:44am |
If you use a trolley jack make sure it can move on the surface it is placed on, with one end of the car on stands the jack will have to move forwards on its wheels as you jack the last end up, if it can't it can tip the other end off the axle stands as the arc of the jack pulls the car towards you... if that makes sense..!!
9th May 2020 11:53am |
Greg,
9th May 2020 12:45pm |
Thanks guys for your responses I feel a bit more confident with it now, just out of interest would this be the axel stand point in the rear?
9th May 2020 3:09pm |
That's one of many suitable points.. Pete
9th May 2020 3:28pm |
Thank you and these at the front?
9th May 2020 3:35pm |
