Hi All,
I have a strange problem that I'm trying to track down on my 3.6 TDV8, I've tried searching around but no luck...
There is a slow oil leak coming from the two rear plenum chamber hoses, it seems to be seeping around the circumference of the hoses, pooling on intake manifold and also leaking down the side of the engine.
So far, I've:
- Checked for damage on inlet manifold/plenum chamber
- Tried tightening and loosening the hose clamps
- Replaced all plenum chamber hoses
- Replaced the inlet manifold gasket
- Replaced the oil seperator
- Cleaned the breather-intake pipe
Other than maybe failing turbo seals (no other symptoms - smoke, oil usage, performance etc.), I'm out of ideas!
Anyone have any ideas/suggestions?
Thanks
