![]() | Home > Technical (L322) > Key Sync on a TDV8 4.4 |
roverguy7 Member Since: 15 May 2020 Location: Virginia Posts: 14 ![]() ![]() |
The truck uses effectively the same system to receive the unlock command from the key as it does for the ignition authorization from the key, so do your locks function using the CDL switch inside the vehicle? |
