![]() | Home > Technical (L322) > Restricted Performance / P0483-27 / P0483-37 - fixed error |
| AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464
The air charge temperature you would expect to be higher than ambient, the turbo's have compressed it, the intercooler will take some of the heat out but it obviously cant get it below ambient.
| Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 342
"Refer to the electrical circuit diagrams and check connections are secure and wiring integrity"
| Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1885
A fan circuit fault will cause R.P faults
| Hojdica Member Since: 04 Oct 2020 Location: Leighton Buzzard Posts: 6
Hi all,
That is normal
| GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2781
As Mikey has noted, the problem is with the cooling fan circuit, nothing to do with intake air-flow. If the cooling fan isn't known to be working as required then performance is restricted trying to avoid damaging the engine from overheating. |
Managed to get to the bottom of this.
