Home > Technical (L405) > Diesel filters
Bill
Diesel filters
Received this from JLR ( I don’t have a diesel light but no matter) 66 year
Q
your Diesel Particular Filter warning light shows as amber on the dashboard, this indicates your filter is filling up and needs to be regenerated. To do this, it’s recommended you drive the vehicle at speeds between 40 and 70mph on roads designated for these speed limits, for 25-35 minutes.
UQ
Suggests speeds of 40 mph for 25 to 35 minutes., whereas the conversations on here suggest higher speeds. ..what’s right?
JLR are not clear about when the regen starts, so how long does it take? I can work backwards.
Thanks. Bill Filters are in fact so good that in certain circumstances, when the ambient air is already polluted, a diesel car will tend to extract more particles from the air than it emits. Emissions Analytics worked with........etc etc
He who dies with the most toys wins...
Post #554751 21st May 2020 3:17pm
I'd have a read of the numerous thread's in the L322 section... you'll get a construtive answer there. ... - .- -.
Post #554760 21st May 2020 3:50pm
Baltic Blue
Greg is the DPF Doctor, but I think we agree .... get it on a motorway, set the cruise control to 55-60 mph and monitor the exhaust temps and soot mass, ( assuming you have an iid) make sure you have at least quarter tank of fuel and 20- 30 minutes later ...bingo... I did mine on Sunday following an oil and filter change , got it down to 4.1g temp just reached 600c,
but I was on my own, so couldn’t take screenshot until next junction.
 G reg 2.5VM Vogue Portofino red 1991- 1999
Post #554763 21st May 2020 4:11pm
Baltic Blue
Stan, so good it could be my Avatar Thumbs Up Rolling with laughter
Post #554768 21st May 2020 4:42pm
Bill
Thanks for the response
Yes I have noted the speed of 55/60mph suggested in previous posts,
I just do a fair bit at 40/50 mph on the lanes, Before I break out onto proper roads , and I was pleasantly surprised by JLR’s message . Hence my question
Post #554773 21st May 2020 6:09pm
Baltic Blue
Personally, I don’t think speed is so critical, but keeping a steady throttle setting is paramount., hence cruise control is good.
Post #554775 21st May 2020 6:17pm
