![]() | Home > Technical (L322) > Air suspension problem on 2011 TDV8 |
Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1100 ![]() ![]() ![]() |
Unless you have a workshop I would suggest replacing the entire strut.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8816 ![]() ![]() ![]() |
The strut bottom bolts can be very tight, you need a decent breaker bar to crack them off..
paulbrown22 Member Since: 23 Dec 2017 Location: London/Poole Posts: 358 ![]() ![]() ![]() |
I had exactly the same earlier this year on my 2011 5.0 S/C - the 9-10 year mark seems to be the life of the front bags...
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
With some trepidation I did mine, if you know how to drive a spanner it's not a hard job. Get some plusgas and soak the relevant nuts and bolts for a couple days prior to starting the job. I bought a gallon of the stuff and a hand spray, gave the area a soaking for a couple of mornings.
AJ, I wouldn't overly disagree, apart from both my bags were rusted to the top of the shaft -- now it may have been with soaking, as you say, that they would have eased off better -- if it weren't for that and then the re-seating of the bottom of the bag (which is very easy with a compressed air line) then I would suggest it could be done on a drive!
