![]() | Home > Technical (L322) > 2004 Rear Brake Calipers |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8816 ![]() ![]() ![]() |
That looks suspiciously like a front one...!!
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8776 ![]() ![]() ![]() |
Try a local motor factor, they are generally a generic calliper so will probably be on the shelf. don’t be scared off a refurb unit. They are normally as good as new. I’ve had a few from factors and they look like new. There is nothing that can't be fixed with a hammer😜😜
crowebeard Member Since: 19 Dec 2016 Location: Devon Posts: 93 ![]() ![]() ![]() |
Pete - Looks like you may be right! It's definately stamped with AF's rear brake code, so suspect there's been a screw up somewhere along the line. Might take the opportunity to do the front ones as well then....
They'll be wanting them sorted as the front ones will be much more money than the rears you paid for... |
All sorted, mix up on the website. Big thanks to Paul at AF for getting the right ones out overnight.
