Home > Technical (L322) > Instrument gauges intermittent L322 '04 |
Richycsurfer Member Since: 18 Nov 2018 Location: Plymouth Posts: 44 |
Has nobody come across this? It seems to happen maybe once in ever 5 starts and takes stopping and leaving the car for a bit to forget it doesn't want to work. My alternator is putting out 14.2V so the battery is assumed ok but maybe it could do with a proper test? |
20th Nov 2018 10:44am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34931 |
try a forum search ... |
20th Nov 2018 10:49am |
It was my first move - nobody i can find seems to have the same things dying on the dash (just gauges) |
20th Nov 2018 1:20pm |
crowebeard Member Since: 19 Dec 2016 Location: Devon Posts: 93 |
While my dials are OK, the digital display used to suffer from a similar fault, it was either on or off and nothing I did made any difference to it and it wasn't just the standard pixel issue either. It's now permanently off.
20th Nov 2018 4:28pm |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1248 |
Do the general backlights work or do they flicker in time with the dials dying to zero. V8 or else ... |
20th Nov 2018 7:25pm |
No flashing it appears. It happened this morning working for around 5 seconds and then died. The speedo, temp and fuel all die instantly but the revs pulse while dropping.
21st Nov 2018 9:12am |
So..gently pulsating fuel, revs and water but flaccid speedo.
21st Nov 2018 10:25am |
Hmm interesting.
21st Nov 2018 8:04pm |
Thanks for the thoughts and reply. Not great news, then.
21st Nov 2018 11:10pm |
the self test stuff should flick the guages through their whole range of motion and back to zero. its a long time since i did mine.
22nd Nov 2018 12:04am |
Mark_L Member Since: 09 Nov 2019 Location: Essex Posts: 2 |
Hi,
9th Nov 2019 7:03pm |
Unfortunately I didn't yet... I've lived with it since however did have some advice to check the earth to the gauges, something which I havnt yet done
9th Nov 2019 9:10pm |
Thanks for the response.
10th Nov 2019 11:04pm |
EJL Member Since: 22 Dec 2015 Location: Belfast Posts: 1 |
Sorry to resurrect an old thread but did you ever get to the bottom of this? My fathers 2005 FFRR Vogue SE has recently started doing the exact same thing. |
8th Jun 2020 2:06pm |
