![]() | Home > Maintenance & Mods (L322) > P040D-00 (2C) restricted performance |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4340 ![]() ![]() ![]() |
Keep us posted |
Andy2986 Member Since: 26 May 2019 Location: Suffolk Posts: 117 ![]() ![]() ![]() |
Told ya ![]() ![]() Glad it's all sorted ![]() If you haven't got the upgraded thicker walled donut hoses then now's the time to get them done ![]() There is a thread on here about buying a length of silicone hose and cutting into 4 etc ![]() 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- Last edited by DrRob on 9th Jun 2020 12:54pm. Edited 1 time in total |
Have you checked the oil dilution figure on your IID? Max is 7 as per Dolphin's advice above. It should have come right down if you reset the service on your IID. This should always be done after an oil change or the car has no way of knowing it has "new oil" for it's calculation. |
I believe the mechanic did but will go and check myself, where on the Iid would I find it ? 2011 4.4 TDV8 1998 D1 300tdi 1971 2 door Classic |
To Be honest, as I had managed to get the garage to look at it I stoped looking until a grown up had had a
Ahhhh found it !!
You definitely have the old donut rubber hoses,
Nice smoke |
Yes !i remember it from when the manifold split. I’m just about to order some 70mm ID silicon hose and new clamps
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
DrRob, JLR have gone back to a third version now which are back to flat again! ![]() |
Thanks Craig - on the SDV8 I assume? Are they prone to splitting? |
