Home > Technical (L322) > Steinhof Tow bars. Now a review.
Anvil
Hi all, done a search and there’s not a lot of reference to these on the forum. Does anyone have any experience of them? Found them for varying prices on eBay and only want it for holding a bike rack, nothing heavy duty. Just thought I’d ask before taking the plunge.
TIA
Simon
Post #556607 5th Jun 2020 7:41pm
Have a look at PF Jones. Plenty of tried and tested options.
Not saying that it won’t do the job, but not heard of them. There is nothing that can't be fixed with a hammer😜😜
Post #556611 5th Jun 2020 8:54pm
Anvil
Thanks NMJ, had a look, and have decided to go for the Steinhof detachable version with 7 pin electrics to match my rack. It is made to EU standards apparently, and will only be used for a bike rack so thothing too heavy. No cutting of the bumper involved etc. Will try to document the installation and give a review, as they are quite a bit cheaper than others on the market.
I'll probably go the belt and braces route and give it a good coat of Smoothrite before fitting!
Si.
Post #556943 8th Jun 2020 5:10pm
Anvil
New Tow bar.
Hi All, for anyone that may be interested in these.....
New tow bar arrived from Poland yesterday. The packaging was a bit battered, as you can see from the photos, but all the parts appear to be there at the moment. First impressions of the bar itself are that its sturdy, and well made. Steel is thick and the welds are of reasonable quality. The powder coat was a bit thin in places, but I'd always intended to give it a few extra coats myself anyway, as 3rd party units always have a tendency to rust from what I've seen. So, it got a coat of stone chip yesterday evening followed by a coat of underseal. I'll let it dry until the weekend when I plan to fit it.
The Wiring loom looks of reasonable quality, and comes with some sort of module and some neat looking plugs. It's well wrapped for both interior and exterior protection, the outside being plastic and the interior stuff being some sort of woven fabric. Rubber seals and grommets are also provided along with a patch of double-sided Velcro to affix the plug/socket to the bodywork.
Tow ball is detachable and comes with 2x keys. the lock doesn't look very high security, so I wouldn't be relying on that if anything of real value is attached. The power socket mount has a neat ball bearing indent mechanism so that is can be rotated out of sight when you take the tow ball off. Tow ball comes with a neat little draw string bag and ball cap to put it in the boot when not in use.
Fixings look of good quality, and will no doubt get a coat of underseal once I've installed and tested everything.
I got the bar from Ebay, and Chris at DG systems was great at answering a couple of questions I had before I purchased. I should also say that I've got no affiliation with the company and paid full ebay price for it, so no special deals were done!
It cost me £246 + £15 P&P all in. For that money initial impressions are very good indeed. Hopefully I'll get a chance to install it this weekend, and will document the install and finish an honest review on it. It will never be used for heavy towing for me as I have no need, but will be used to mount my Thule Bakrack that I've got bike mounts on.
Cheers All! Very Happy
https://www.ebay.co.uk/itm/Land-Rover-Rang...2749.l2649
Post #557888 16th Jun 2020 12:38pm
The detachable bit seems to be made by ACS, which are a ductch company who specialise in detachable tow bar bits. from the look of some of their couplings they look similar to ones Brink use. Otherwise looks pretty solid.👍🏻 There is nothing that can't be fixed with a hammer😜😜
Post #557906 16th Jun 2020 4:37pm
Anvil
Yep, seems to be so far. I'll keep everyone posted with how easy/difficult it is to install if anyone's interested!
Post #557910 16th Jun 2020 4:45pm
Gsxr1250dave
I'm watching this as I'm still in the market for one at some point so I can mount my spare wheel to the tow hitch.
A guy on the bay sells tow hitch mounted wheel carriers
Post #557919 16th Jun 2020 5:54pm
Anvil
Thumbs Up Thumbs Up
Post #557944 16th Jun 2020 9:34pm
Anvil
Steinhof Towbar installation.
Hi All, So I got around to installing the tow bar over the weekend. Spent quite a bit of time doing it as I'm a bit anal about cabling and stuff, but if you plan to do it properly, and you're doing it alone, I'd set about a day aside.
First part was removing all of the interior trays and stuff from inside the boot area to expose all of the wiring. There's vids on You tube, so I'm not showing that bit. My Rangie was not pre-wired for towing, and in any case I don't think this kit would be compatible with existing plugs.
I took the module with all the cabling, and it turns out that this little box of tricks works like a load of little relays, so the lights effectively run off their own circuit rather than "sharing" the power off the existing lights via a direct splice. it has a fully independent earth and feed that powers your trailer lights. (Or in my case, my bike rack!). It also has an audible tone that beeps at you when you turn the ignition on, when something is attached. (If you're dense enough to forget you've got a trailer.... !)
Here it is velcroed with the supplied patch in place.:
I took most of the feeds for the lights off the nearside light as it kept the cables short and there's a perfect little square rubber grommet you can feed the cables through to the exterior plug assembly. The instructions for the plug itself are good and relatively easy to understand. What wasn't so clear was the instructions for the Live feed to the module via the heavier gauge red wire. There is also a 10A fuse and in-line holder that should be attached at the supply end. (More of that later:)
At the rear of the boot, there is a void that you can use to pass the cables that need to be connected to the offside light, and also aforementioned red Power feed lead. all connections and loose wires were taped up and zip tied into place.
I never trust wiring diagrams, and prefer to use a meter to check my connections etc so as not to create a short by accident. I did this by pulling out the rear light assemblies and identified the correct wire colours with the aid of a 9 year old to push buttons and press brake pedals etc. Connections all taped up and neat:
The heavy red cable you can see top centre of this photo (Off side) is used for the module's power feed. Be SURE to utilise the fuse and spade connector provided to protect this cable as close to this post as you can. The spade fits neatly under the nut on the post.
Near side connections taped. They got zip-tied out of the way later.
Bumper then gets removed. -Again there's Youtube vids for this so I'm not going into detail. Be careful to disconnect your parking sensor plug on the offside corner as the bumper comes off to allow full removal. Easier with 2 people, but not impossible on your own.
You can see the 2 main bolts each side fthat hold the factory towing eyes and exhaust hangers. Stick a jack and a block of wood under your exhaust to support it as the hanger brackets get removed and replaced with new ones in the kit.
Hanger:
And the one at the rear:
This shows the offside assembly removed but the nearside still attached. Note the Jack under the exhaust.
Freshly stone-chip and undersealed tow bar ready to fit:
Slather on a load of silicone sealant to keep your boot dry.... I also put another load on over the top of the bracket on the bar before the bumper was refitted.
Here's the grommet you can feed your cabling out to the exterior plug I slapped a load of silicone around that too and at the cable exit.
Bolt the unit into place using the original factory bolts at each of the four points. I Struggled a bit on my own to do this. The unit is very heavy, and manouvering it into place to fit the angled exhause hangers probably should have been a 2 person job. Obviously not impossible, but I'll see how much I ache tomorrow....
It fits really snug to the chassis memeber at the back so take care not to pinch your cabling.
Here's the plug in the "up position" -It's on a ball bearing detent system so can be rotated when not in use.
Here's the plug in the "down position":
Here she is all back together with the ball off, and the plug out of the way. Shame its not all completely out of sight, but certainly a bit more discreet than some.
All in all, I'm very pleased....
Notes: there were 2 small flat brackets that came with 4 smaller bolts to fit to the bar. They didn't attach to anything else at all, so I left them off and don't see the point of including them on my S/C. Maybe they are for a different exhaust system? I'd be interested to hear your ideas. They can be seen here just below the ball cap:
There really is nothing to bolt them to and they are too small to be anything structural for towing.
So its a big thumbs up from me for this tow bar. Happy to take any questions if you have them.
Si.
Post #558600 22nd Jun 2020 2:54pm
Gsxr1250dave
Very nice right up that man......well done!!!
Post #558603 22nd Jun 2020 3:02pm
Anvil
Thank you!
You are more than welcome sir Thumbs Up
When I have 5 mins, I may further paint the plug bracket to keep away the tin worm, and also the nice shiny hitch bolts so that they are not as obvious......
The ball attaches very solidly with no play at all. Top job.
Si.
Post #558611 22nd Jun 2020 4:21pm
stuart_2006
You do have a prewired towing socket - it's the white connector in the second of your photos. I was fortunate with the towing kit I got from PF Jones that it came with the socket to fit this, so I didn't have to play with splice connectors. Phew!
Post #558667 22nd Jun 2020 10:48pm
4434Morrison
United Kingdom 2012 Range Rover Vogue SE TDV8 Santorini Black
Excellent write up - thank you.
You have enabled me to decide to fit the Steinhof bar instead of the Westfalia bar on my 2012 TDV8, 2012 4.4 TDV8 Vogue SE Current
2015 E220 with AMG Sport Pack - Currently driven by my son
2010 3.6 TDV8 Vogue - Written off by my son
Post #558673 23rd Jun 2020 5:36am
Anvil
Ahhh, interesting! Thanks. That may have been an alternate point to splice in the connectors all in one place then. The loom that came with the kit aligned nicely with the exit grommet etc, so I'm quite happy with the results. Worth noting for others who need a splice point though. Cheers. Thumbs Up
I guess that plug would be handy if I ever wanted to run a 13 pin set up too, and all I'd have to do would be to buy the electrics kit.
Post #558689 23rd Jun 2020 9:22am
Anvil
No Problem. You're welcome. The only thing I could pick it up on was the finish and coverage on the powder coating in some of the difficult to reach areas. If you're prepared to paint it yourself before install, its otherwise a quality product as far as I can see. There are several variants available in detachable/fixed ball, 7 and 13 pin electrics. Make sure you get the right one, as the ebay photos are all the same which is a little misleading.
Post #558691 23rd Jun 2020 9:26am
