Home > Maintenance & Mods (L322) > Lower Tailgate Cable Disconnected
Westminster
Hi all,
The lower part of the support cable on the driver side has come unattached from the lower part of the boot, not the car end.
It seems like the nut inside the lower tailgate has disappeared as there is now a hole only, but no thread to reattach it to.
Any idea what parts I need and do I have to take much apart?
Many thanks,
Tim
Post #556731 6th Jun 2020 8:51pm
Pretty sure it's a captive nut...
What is left on the strap..? Pete
-Click here for Thread-
Post #556740 6th Jun 2020 10:11pm
Westminster
The strap has the bolt that should screw in the lower tailgate but there is nothing to screw into, just a hole.
Post #556742 6th Jun 2020 10:55pm
As I said, pretty sure it's a captive bolt which must have come off....
Maybe undo the other side and see... Pete
Post #556743 6th Jun 2020 11:02pm
Load up a pic sir... Thumbs Up
Post #556745 7th Jun 2020 12:00am
Westminster
Yes I realised it was a captive nut but if it's sheered off it may require sorting at the garage rather than my just buying a replacement part, thought someone might know for sure that's all.
I would post a picture but there really isn't much to see, just a hole!
I'll ring LR parts tomorrow and see if they've got a diagram and can tell me.
Thanks.
Post #556799 7th Jun 2020 4:00pm
as Pete says, look at the other side and you'll see what's what.. ... - .- -.
Post #556807 7th Jun 2020 4:23pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
It`s called nut-set works like a pop-rivet.
Post #556813 7th Jun 2020 4:45pm
stuart_2006
Had the same problem when I replaced my tailgate straps - the nut came off on one side. If you remove the plastic trim along the top of the tailgate (the screws are fairly obvious) then you can get behind the carpet, find the nut rattling round inside the tailgate somewhere, then hold the nut in place while you screw the strap back in.
Post #556867 7th Jun 2020 10:48pm
Westminster
Thanks that’s very helpful, hoped it would be something like this!
Post #556908 8th Jun 2020 11:36am
