Home > Technical (L322) > Soot content
Gazcw
United Kingdom 2011 Range Rover Vogue TDV8 Baltic Blue
Soot content
Yesterday I was monitoring dpf and soot went from 13.9 to 20.9 over a 20 mile journey. Gulp!
This morning I cleaned the Map on top of the doughnut, checked hoses and cleaned maf. The maf and the throttle body were pretty much clean. The map however was well choked up.
After putting all back together. Went out and the soot had gone down to 16.9. Interesting! I did what I had to do and then went for a drive. Levels got to 17.6 after 25 miles or so and then regen started. So all is fine with that and got down to 13 before running out of time.
Not sure if this is just a coincidence. Anything thoughts? 2011 4.4tdv8 Vogue
Baltic Blue
Post #556795 7th Jun 2020 4:46pm
DrRob
Reminds me I must clean my MAP. Is MAF easy? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #556802 7th Jun 2020 5:10pm
Gazcw
Easy. Remove hoses unclip and that allows access to the maf. I didn't disconnect or remove the maf at all. Sprayed with brake cleaner and gently wiped up excess.
Took 15mins max 2011 4.4tdv8 Vogue
Baltic Blue
Post #556805 7th Jun 2020 5:15pm
DrRob
Good idea. Leave wiring connected and clean it in situ with lots of blue roll to catch the drips? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #556814 7th Jun 2020 5:46pm
