![]() | Home > Technical (L322) > DPF Regeneration Frequency. |
| Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3883
I seem to have worked out that B.B. my 4.4 tdV8 does a regen approx. every tankful.
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352
You’ve now got me wanting to go out and plug mine in |
| SFM Member Since: 19 Feb 2012 Location: dordogne Posts: 263
NO NO NO!!
Rob,
Cheers Mike. Must update mine. I looked last night and with ignition on only the Number of successful regens and partial regen fields said "N/A". I'm sure I've seen them before but maybe only when engine is running.
Mileage: 100158; Number of successful regenerations: 185
Engine needs to be running for "Number of successful regens" to show on IID. Won't show with ignition on only. 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years I use www.glenrands.co.uk Great independent specialist! -------------------------------------------------- |
I will check number of demanded regens next time Rob and update you.
I changed my oil in Jan and it's due mid July. Hardly done any miles from mid March to date. So the 0.8 dilution is for Jan to mid March. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Rob,
I’ll check via IID but I think it’s a shade over 2000 miles since oil change which would be about right with my man maths. Roughly 0.4-0.5 for every 1000 miles |
Hi Dr Rob
According to the W.M bible , the oil service indicator says due at contamination of 7%.
Yes, according to dolphinboy and Mike's workshop manual posting 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years I use www.glenrands.co.uk Great independent specialist! -------------------------------------------------- |
| TeeMyob Member Since: 22 Jun 2019 Location: Javea/Manchester/Abu Dhabi Posts: 213
What are you using to get the data ? |
| All times are GMT |
