Home > Maintenance & Mods (L405) > Took front bumper off - what's this mystery wiring loom?
pherplexed
United States
Removed the front bumper of my L405 to install the adaptive cruise control module and spotted this unused wiring loom behind the grille, right next to the horns.
Anyone know what it's for? Didn't think to look for a part number at the time.
 2021 P525 | Eiger Gray
Post #557894 16th Jun 2020 2:25pm
dingg1
Winch?
Post #557909 16th Jun 2020 4:42pm
Could be for additional fans in hot climate. There is nothing that can't be fixed with a hammer😜😜
Post #557911 16th Jun 2020 4:45pm
jackcramerr
How do you guys find out what can be retrofitted?
What about lane assist?
Post #557913 16th Jun 2020 5:08pm
pherplexed
United States
There's a master thread somewhere with a list of all the things that can be retrofitted to date. Can't seem to find it at the moment.
Specifically for the Adaptive Cruise Control, I followed this thread to figure out it was possible. 2021 P525 | Eiger Gray
Post #557915 16th Jun 2020 5:16pm
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
I'm half way through the modification at the moment. Information I'm using is:
www.fullfatrr.com/forum/topic47538.html?hi...se+control
www.rangerovers.net/threads/adaptive-cruis...-to.340817
1. Radar Distance sensing unit
β€’ PN - LR062658
β€’ Bought Delphi JS301111640078
β€’ Described as and looks identical to L494 cruise control radar sensor, FPLA-9G768-AC
2. Bracket
β€’ PN – LR033405 or LR060076
β€’ Bought from LR (Β£16.33)
3. Steering wheel switch
β€’ PN - LR087486 or LR037452 (LR071935?)
β€’ Β£45.22 +vat from lrparts.net (Β£54.26)
β€’ Ebay - Β£61.95 (Β£64.61 from LR)
β€’ Bought from forum (Β£30)
4. Programming – Get into "Full CCF Function"
1. Speed control - Current: Adaptive cruise control is fitted
2. Adaptive speed control ECU - Current: North America, Canada, Mexico, Australia
3. Adaptive speed control ECU – Current: standard blockage level -40dB
4. Collision mitigation by braking – Current: Fitted
5. Standard speed control display type – Current: Adaptive speed control full display plus priority messages
6. Speed control - Current: Adaptive cruise control with queue assist
7. Adaptive cruise control indication in instrument cluster - Current: Enabled
8. Speed control – Current: Adaptive speed control, stop and go
9. Collision mitigation by braking – Current: Collision mitigation by braking GEN3
10. Forward collision warning – Current: Forward collision warning GEN3
11. Front crash sensing system – Current: Front crash sensing system – upfront sensor
Then: instigate sensor alignment
Hardware is all in, and just working on the programming. Trying to understand JLR SDD enough to see if that will allow me to get into the Cruise Control Programming. Apparently someone has done it via IID, or alternatively take it to a local (good) specialist with access to programming. Current:
- 2013 L405 4.4 TDV8 Vogue
Sold:
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #557917 16th Jun 2020 5:30pm
pherplexed
United States
Did my programming with the Gap IID tool. Very easy process, but you have to contact GAP for them to give the tool access to the full CCF for modification. 2021 P525 | Eiger Gray
Post #557918 16th Jun 2020 5:32pm
