Home > Technical (L322) > Air suspension
Simon_CSK
United Kingdom 2008 Range Rover Vogue TDV8 Adriatic Blue
Air suspension
The message on the dash came up as Suspension will rise when cooled, what does this mean?
Also can anyone tell me how many different types of compressor there are for the suspension please? I am told that there are round boxes in the floor and square boxes. This is all I know at the moment as I am a newcomer to the L322. Current cars
Range Rover Sport HSE TDV8
Range Rover TDV8 Vogue
Range Rover P38 Vogue
Range Rover CSK
Discovery 3 HSE
Post #558117 18th Jun 2020 12:46pm
Brian Considine
I could be wrong but it seems to me that the compressor has worked too hard/overheating - see what happens when it's had time to cool off. 2003 Range Rover Vogue TD6
Post #558124 18th Jun 2020 1:28pm
400-ascona
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Java Black
That is indeed the reason. The pump is thermally overloaded. You either have a leak somewhere in your system which is resulting in your pump running too often or you have something wrong with the pump itself.
In my experience, the pump may/should run briefly when you first start the engine, but should very rarely run again during your journey unless you adjust the height of the vehicle at any point. A pump that runs regularly indicates a leak somewhere.
The common issues with the pump include a split cover plate, worn piston seal, but way more likely, clogged and restrictive desiccant. If you have no leaks, I would go for a change of desiccant and filter pads first. This certainly fixed my issues which also included a reluctance to lower without going into extended mode.
Rob 05 L322 4.2SC
2016 Discovery 4 Graphite
Lotus Carlton
Ascona 400
Volvo V70R AWD manual
Suzuki 1200 Bandit
Velocette Venom
BMW R80/7
Daimler V8 250
Mini Cooper S Works 2006
Post #558132 18th Jun 2020 3:23pm
AJGalaxy2012
Check you dont have a leaking suspension airbag. BMW i3 Electric Car
2006 VW Touareg 3.0 TDi V6
Post #558153 18th Jun 2020 6:11pm
Put the car in off road height, turn the engine off, leave a door open so the suspension doesn't level and listen to the wheel wells, you should be able to hear the leak.. if you can't then disconnect the battery and see if the car drops overnight, if it doesn't then take a look at your pump.. Pete
-Click here for Thread-
Post #558155 18th Jun 2020 6:43pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Pumps? AMK recommended by JLR. Hitachi was fitted by JLR, Dunlop very cheap easy to repair check U-tube
Post #558156 18th Jun 2020 6:47pm
