![]() | Home > Technical (L322) > Restricted Performance L322 2011 4.4 |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3556 ![]() ![]() ![]() |
yes you can douse the CSOV Ian.
Ianclark1275 Member Since: 11 Apr 2020 Location: York Posts: 67 ![]() ![]() ![]() |
Thanks for the reply,
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3879 ![]() ![]() ![]() |
I called out LR Assist the first time mine through up R.P. alarm and he diagnosed it from the fault code.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4348 ![]() ![]() ![]() |
Ian - looks like yours has the nut still on the CSOV. Needs the modification but get codes read first as it might be something else |
PS Use JAS Land Rover nr York. One of the best independents in your neck of the woods |
Thanks all, i will get codes read,
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 700 ![]() ![]() ![]() |
That actuator rod, can it be manually moved & at the same time a dollop of WD40?
I tried with hand but couldn’t reach
Codes are listed in a section of the workshop manual in the wiki |
Thanks buddy
