Home > Technical (L322) > Air con playing up
SFM
France 2012 Range Rover Vogue TDV8 Rimini Red
Air con playing up
Hi all
So....the past few days it been impossible to get any air out of the vents, fans running flat out , but no airflow.
Keep pressing all the buttons, nothing.
Switch the engine off, a couple of times, and then it starts working ok, nice cold air.
Iid says air quality control sensor going to ground ( or something like that)
It was 34’ here today, and a miserable drive home from the shops!
Any idea where this sensor is located, or anything else i can try?
Steve
Post #558916 24th Jun 2020 9:15pm
millerj90
If that message is referring to the Pollution Sensors, then it’s here. Depending on model it could be left or right.
Post #558919 24th Jun 2020 9:25pm
SFM
Items 7 and 8?
Can you get to them easily?
Cheers
Steve
Post #558923 24th Jun 2020 9:37pm
millerj90
Yes. You only have one. My TDV8 was on the left hand side when facing the vehicle.
Piece of cake, open the bonnet and it’s there on the fan cowl.
Post #558927 24th Jun 2020 9:58pm
Don't think that will have any effect on your problem, my last fatty had that fault all the time I owned it and it made no difference to how much air comes out, it just decides if the air quality is low and if it is it switches it to recirculate..
I would suggest it's more likely the blend flap actuators which I think you can test with the IID..
Good luck Thumbs Up Pete
-Click here for Thread-
Post #558930 24th Jun 2020 10:07pm
SFM
Hi Pete
Is there a fix, or is it replacement by dealer?
Steve
Post #558937 25th Jun 2020 6:57am
SFM
Sorry guys
Can you tell me what side the air quality control sensor is on, I’ve looked, and cannot see anything that looks like what you are describing.
Will try and order a new one from Duckworth.
Makes sense that if the sensor thinks air quality is not good it would shut the outlets.
Steve
Post #558965 25th Jun 2020 11:50am
millerj90
Post #558968 25th Jun 2020 12:00pm
SFM
But yours is a l405
Mine is an l322
Post #558970 25th Jun 2020 12:12pm
SFM
Sorry you were talking about your previous car!😩😩
Don’t suppose you know the part number?
Steve
Post #558971 25th Jun 2020 12:15pm
millerj90
Steve
I found this thread. It has loads of info and photos, and the bottom of page 1 gives the part number, and a copy of the dealership parts computer.
Hope it helps.
https://www.fullfatrr.com/forum/topic28100...p;start=15
Post #559000 25th Jun 2020 4:19pm
SFM
Sorry guys,
I might be being a bit thick here, opened the bonnet, had a good look with a torch....cannot see anything that resembles what was posted. Definitely noting on the left hand side of the cowl.
Please help, as it been very warm here the last week!
Steven
Post #559553 29th Jun 2020 10:03pm
SFM
Sorry chaps
Ordered a new sensor today, but still can’t find the old one!
It’s meant to be on the left side of the radiator, half way down the cowling, but I can see nothing.
Am I stupid?
Post #559645 30th Jun 2020 5:33pm
SFM wrote:
Hi Pete
Steve
Sorry Steve, missed your reply...
Like I say, don't think the air quality box will solve your issue, but worth a try I suppose...
Think you will find its the flaps not working properly especially as you can get it to work for a bit...
There maybe some reset procedure for them, if they need replacing some are easy others are a nightmare...
Good Luck.. Thumbs Up Pete
Post #559648 30th Jun 2020 5:40pm
