Home > Maintenance & Mods (L322) > Air Suspension
ricky25
United Kingdom 2003 Range Rover Vogue Td6 Rimini Red
Air Suspension
My L322 Range Rover 2003 has developed an air suspension fault. No fault shows in the display but the lights in the centre console regarding ride height are not on. Air suspension is not working. Any suggestions please ? Thanks.
Post #560267 4th Jul 2020 11:28pm
First try a battery disconnection procedure to see if that clear any soft or hard faults (see wiki)
If that doesn't work then you will need a diagnostic tool that can read LR air suspension codes (e.g. IID Tool) in order to read the faults and clear them.
You can do a visual check under the car to look at the height sensors and wiring, and also for any visible holes in the air bags.
Most likely suspects - in this order:
Height sensors
Air bags
Compressor
Reservoir
Valve Blocks & piping
ECU .
Post #560286 5th Jul 2020 9:32am
I would consider buying one of these eas/abs reset tools. Very useful piece of kit.
eBay number,
eBay Item No. 183379533939
Post #560296 5th Jul 2020 11:16am
