Home > Maintenance & Mods (L322) > TD6 Alternator Fault
mercs600
England 2002 Range Rover Vogue Td6 Java Black
Having had my battery light come on intermittently whist driving and then lots of strange messages/faults on the dash , I tested the voltage output at the battery with the engine running and had 12.5 volts. Eventually the battery light remained on and I was only getting 11.5 volts so I knew I had an issue with the alternator. Reading other posts and also the Land Rover manual everything says to remove the viscous fan etc. to gain access and remove the alternator . I managed to remove the alternator from the top of the car without touching the viscous fan, the only issue was re-fitting the drive belt whilst moving the belt tensioner. I removed the diode rectifier pack from the rear of the alternator and found the carbon brushes extremely worn with one hardly touching , hence the low output voltage ! I purchased a new pack off Ebay which stated it was correct for the TD6 but it turned out it was not . However with the vehicle stuck in the drive I just de-soldered the brushes and swapped them over , rebuilt and cleaned the 2 x copper slip rings. Rebuilt everything back up and now getting 14.2 volts Smile Job done and saved a few hundred pounds Smile What I also found after doing all this is that it is possible to access the rear of the alternator from underneath the car and there is a plastic cover over the carbon brush gear that can be removed to check condition. It is also possible to change the diode pack as well without removing the alternator !Just ensure the battery is disconnected when carrying out this procedure Smile
Post #560873 10th Jul 2020 8:08am
Useful to know Thumbs Up
What mileage did your alternator start to fail at?
Post #560883 10th Jul 2020 10:54am
mercs600
nicedayforit - alternator started playing up at 168K Smile
Post #560909 10th Jul 2020 5:06pm
Ok thanks, got a while to go then Thumbs Up Very Happy
Post #560916 10th Jul 2020 6:11pm
wayneg
mercs600, Any pics of the process, Is it similar to this video ? https://www.youtube.com/watch?v=aVvPzwtxdrM 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #560949 11th Jul 2020 4:18am
