|  | Home > Maintenance & Mods (L322) > rear wipe problem L322 |
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8002      | Ahhhh, the joys 🤣 I’m not sure if they did the same on the X5, never had one so don’t know. I assume they learnt and do something different now.... 2011 Range Rover Vogue SE 4.4 TDV8
|  15th Jul 2020 9:03am |
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8002      | It was always gonna be a new motor. Had a new one on my TD6 and never had any issues after.....
|  15th Jul 2020 1:58pm |
| billybob Member Since: 14 Jul 2020 Location: worcestershire Posts: 12      | Yep, it should resolve the problem, I also ordered a new pump as I guess its burnt out, thanks for your advice. | ||
|  15th Jul 2020 2:04pm |
| PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1263      | Being serious for a moment, I'm sure there was a write up on here some time ago about the rear washer and a mod(?) that could be done to improve the seal around the washer tube.
|  15th Jul 2020 3:21pm |
| billybob Member Since: 14 Jul 2020 Location: worcestershire Posts: 12      | I'll take a look, see what it says, well, I will if I can find it.
|  15th Jul 2020 3:45pm |
| V8Noise Member Since: 25 Apr 2015 Location: Dereham Posts: 424      | The write up is in the Wiki and it's a dead easy job. I fitted a new unit myself and about 4 inches from the pump is the non return valve. Take that out and see how much water comes through when you switch on the rear washer. Have your beautiful assistant hold the pipe and you can usually drown her. Te he. 2017 5.0 Autobiography Supercharged
|  15th Jul 2020 3:51pm |
| billybob Member Since: 14 Jul 2020 Location: worcestershire Posts: 12      | I'll see what my beautiful assistant says about holding my pipe to be caught out by the water. I feel a slap coming on. | ||
|  15th Jul 2020 4:22pm |
| All times are GMT | < Previous Topic | Next Topic > |
| Posting Rules
