Home > Technical (L322) > VIN code.
Johnte
VIN code.
Is the VIN code stamped anywhere on a 2006 FFRR apart from on the plate inside the screen, I just want to check numbers on one I'm viewing.
Post #60432 15th Apr 2011 11:24am
on a plate under the bonnet and ,i think, under the carpet drivers side.. ... - .- -.
Post #60436 15th Apr 2011 11:58am
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
Re: VIN code.
if you PM me the VIN number i can check it against the land rover system and let you know the model/colour/options the car should have
Matt
Post #60447 15th Apr 2011 1:39pm
nick h
2005 Range Rover Vogue 4.4 V8 Tonga Green
Re: VIN code.
Matt
thats the best option
Dan did it for my vogue - full 'build' spec etc - very interesting
Post #60449 15th Apr 2011 1:46pm
Johnte
Re: VIN code.
Matt
Thanks, if I get it I'll take you up on that Thumbs Up
At the moment, I just want to check the stamped numbers match with those on the screen.
I may be a bit paranoid, but a good few years ago I had a Cosworth Sierra Embarassed and didn't check until it was too late Big Cry
Post #60455 15th Apr 2011 2:15pm
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
VIN in 2010MY "may also" be (that's a quote from my Owners Manual!) in the following locations, I don't know if it is the same for all MY's
Service record book
Bonnet locking platform
On the suspension tower (It dosn't say which one though, it might be all of them!)
On the door shut faces 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #60471 15th Apr 2011 3:14pm
