![]() | Home > Technical (L322) > 5.0 SC water and white smoke out exhaust |
WB Member Since: 26 May 2016 Location: London Posts: 303 ![]() ![]() ![]() |
Have you heard a 5.0 supercharged that is in good health to compare to? These direct injection engines do make a bit of noise especially when cold - a bit like a diesel but as mentioned on your other thread there's a good likelihood it needs the belt chains/tensioners replaced. The white smoke could be a number of things ranging from very serious to quite minor so you're taking a huge gamble if you can't get the car inspected before buying it. This sounds like a car to walk away from and it's probably being sold because of the cost of repairs.
Hammer Member Since: 14 Oct 2012 Location: Perth Posts: 124 ![]() ![]() ![]() |
Hi WB
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1036 ![]() ![]() |
It's on the auction for a reason......its fecked |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16403 ![]() ![]() ![]() |
If you’ve never heard another SC running then I think your taking a massive risk/gamble sir!
Thanks Craig
fecked- is that an extra with Autobiography ![]() 2007 TDV8 Vogue 2000 P38, Gen3s, 2 inch lift, KM2s 285/75/16 |
