Home > Technical (L322) > My L322 Vogue sits ever so slightly lower at the rear
ChrisRRV
United Kingdom 2004 Range Rover Vogue 4.4 V8 Tonga Green
One thing ive noticed about my L322 is that it sits slightly lower at the rear than the front.
I thought it was maybe the airbags leaking but the compressor doesn't run all the time to compensate for a leak and there doesn't appear to be any bubbles forming around the bags when sprayed with fairy liquid and water.
I was wondering could this be anything else or is it the bags starting to go?
Its not massively noticeable but some times it sits level after getting out of the car and some times its slightly down. But not to just one side its an equal level on both sides at the rear.
Any help would be great
Chris
Post #563676 5th Aug 2020 2:08pm
by design the front is higher by one cm to the rear.. ... - .- -.
Post #563679 5th Aug 2020 2:22pm
CS
Both my 322s and indeed my P38 did this to some extent when older, especially my 2004 322 which was almost 10yo when I traded it in. Apart from taking a bit longer to get up to level after starting it did not seem to affect operation, I just put up with it. Only Range Rovers since 1988
Post #563683 5th Aug 2020 2:39pm
ChrisRRV
Thanks for the clarification
Ill measure them both just to ensure its matching up
Saw another l322 yesterday and it was the same height all the way round, shocks and springs setup i take it rather than air?
Post #563684 5th Aug 2020 2:40pm
the suspension could have been adjusted level using an iidtool.. ... - .- -.
Post #563694 5th Aug 2020 3:00pm
