![]() | Home > Technical (L322) > TD6 dash bong when accelerating from cold |
V8Simon Member Since: 18 Dec 2019 Location: North Wales Posts: 20 ![]() ![]() ![]() |
My 2003 TD6 does similar but I've presumed its because its at the lowest setting on the suspension which has a 25mph max speed and it takes a min before it triggers the pump to raise up to normal height???? 2004 Vogue SE TD6
clemenz Member Since: 13 Sep 2014 Location: Graz Posts: 183 ![]() ![]() ![]() |
I notice the same sometimes, also when i need to push it hard it has one gear shift problem from 1-2, second attempt is fine then. Definitly no bong because of suspension, only accoustic allert no message, no failure in ecu! It‘s mysterious! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35837 ![]() ![]() |
i believe that there are gear restrictions until the engine and gearbox is warmed up and the oil is flowing..
